    17
    Default Replacing Lamp post lights
    I recently purchased new lamps for my post light along my driveway with the intention of replacing the existing lamps only, not the posts. When I received the lamps I realized that the base is larger than the post. Is there a conversion part I can purchase to adapt the size difference. Whe
    N I bought the lamps ****** the site did not ask for the size of the post. Thank you for any advise.
    Columbiana, Alabama
    843
    Default Re: Replacing Lamp post lights
    You probably could get some sort of reducer/expander but if it didn't come from the light manufacturer, it wouldn't look too good.
    Since the posts only cost about $20 each you might want to swallow hard and replace them.
    Maurice Turgeon, thesemi-retiredelectrician.com
    17
    I was afraid of that! I certainly don't mind the cost of the posts but what started out to be somewhat of a simple project to update the lights sounds like a project for an electrician. Go figure! Thank you for your help
    Sep 2009
    florida
    598
    #1 What size is the outside "dimension" of your existing post ?
    #2 What size is the inside dimension of the new light ?
    #3 Is you existing pole set in concrete ? If not replacing it may not be a big deal. If it is then there's more work involved.
    Depending on the OD size of the existing pole and the new light you may be able to slip a larger pole for the new light over the old pole.
    Gizmo
    Hidden Content
    Hidden Content
    17
    Smile Re: Replacing Lamp post lights
    The OD of the existing post is 2 1/4 inches and the OD of the new lights is 3 1/4. The 3 posts line my driveway in a mass of English ivy so I am not sure if they are set in concrete yet. But I am excited about the idea of setting larger post over the existing posts! That just may be my solution! Thank you!
    Sep 2009
    florida
    598
    Quote Originally Posted by Loveswood View Post
    Good Luck,,,,,,,
    http://tinyurl.com/4blrku7
    http://tinyurl.com/4zrozgd
    http://tinyurl.com/4u73cgg
    Gizmo
    Hidden Content
    Hidden Content
