    Feb 2011
    indiana
    Default kitchen wall support
    My house is ten years old,I have arched opening leading from the family room into the kitchen. When they were putting the wall up I noticed that the wall started to sink. The workers went downstairs into the basement and put a 2x4 perpendicular on a support beam running parallel with the wooden I joist. I wasn't to confident with that so I added some floor jacks for added support. The problem is a crack appears in the drywall every year because of movement and I was wondering what was the best way to fix this?
    Jan 2009
    Needham, MA
    559
    Default Re: kitchen wall support
    any chance of geting a pic of the work done in the basement and the kitchen opening? if you do post some pics, let us know where the work in the basement is done in relation to the opening in the kitchen.
    thanks
    3,155
    Were the supports placed in the basement before or after the load was added to the floor above?
    If it is a seasonal crack appearing, that could just be the normal expansion and contraction of your home with heating and cooling cycles.
    Quote Originally Posted by indiana randy View Post
    Is this a bungalow or is there a second floor above? The issue can be different for the type of structure.
    For example --- generally a 10 year old bungalow likely has engineered roof trusses which eliminates the *support* walls that you find with stick framed roof/ceiling assemblies. In which case the cracking appearing with seasonal changes is likely *truss uplift*.
