Thread: Tin Backsplash
    Feb 2011
    Default Tin Backsplash
    We have a tin backsplash that was previously painted (primer and then oil based paint) Is it possible to remove the paint and restore the tin without damaging it?
    1,383
    Default Re: Tin Backsplash
    Probably more cost-efficient to replace the tin. Stripper will be messy, hit-and-miss, and you will still have to paint the tin, otherwise it rusts.
    If you want a metallic look, just repaint w/metallic enamel.
    Casey
