    Apr 2008
    32
    Default New dimmer doesn't dim
    I recently replaced an older dimer (likely mid to late-1980s age) with a new Leviton slider dimmer (model IPI06). This is a three way switch and the dimmer controls the light fixture on the ceiling fan. A second switch in the box controls the fan, and a second set of switches in an adjacent room independently control the same light and fan.
    I wired the new dimmer in and it will turn the fan light on and off, but will not dim, even after I followed the instructions and used the small dimming adjustment screw.
    I have a basic knowledge of wiring and the instructions included with the dimmer are not the greatest. The box contains a ground (green), white, black, and red wires; the dimmer has two reds (one of which is used only with a 3-way switch), a green, and a black. I connected the two blacks, the two greens, two of the reds, and the box neutral (white) and the second red wire. After no dimming, I switched the two reds from the dimmer around and got the same result. Trying to avoid calling my FIL (he's an electrician). Any ideas here?
    Thanks
    -Daryl, learning how to keep up with an 80 year old house in PA
    Columbiana, Alabama
    822
    Default Re: New dimmer doesn't dim
    Since the light can be controlled (on & off) the dimmer may be bad, wired wrong or the bulb is a compact fluorescent and can't be dimmed.
    Maurice Turgeon, thesemi-retiredelectrician.com
    Quote Originally Posted by valleyboy View Post
    Thanks
    Perhaps I'm misunderstanding what you posted --- did you connect the second red wire on the dimmer to the white neutral ?
    If so, you don't do that.
    The red wires on the dimmer are the travellers in a three way switched circuit.
    Apr 2008
    32
    Thanks for your replies, gents. To answer semi, the bulbs are incandescents, and after trying multiple combinations of wire to wire, I always got the light to come on, but was unable to dim it. I'm going to return the new dimmer unit, as the only thing I can conclude is that I got a bad unit (not the first time; ask me how many times I've purchased GFCI's that have not worked out of the box or have failed within an unreasonably short amount of time).
    Canuk: if I don't connect one of the reds to the box white, then what do I do with it? The wiring between the box and the old dimmer was as such: black to black, green to green, red1 to red, red2 to white.
    Thanks
    Feb 2011
    Brown county, Ohio
    52
    Smile Re: New dimmer doesn't dim
    Ok the way i understand this is you have a 3 way dimmer on one side and a switch on the other side. Which one is the return and which one is the line side. I would ring out my wires and make sure i knew which ones were travelers and what is hot and what is the return. After you have done that i dont see what the problem would be unless what you and maurice said about the dimmer being bad. Good luck buddy. Nothing worse than calling the fil. I know mine is a retired pipefitter and i will mess up some plumbing before i call him.
    Thanks
    Thanks
    Just going on what you posted previously--- connecting one red wire from the dimmer to the white neutral .
    You don't connect a *switch feed* ( or in the case of a 3 way switch --- a *traveller* ) to a neutral.
    Add that to your basic knowledge of electrical.
    Remember --- we can't see over the internet what's what there. We have to go on whatever information you provide.
    Now , based on further information it seems the *white* is not a neutral but rather is being used as a traveller. In which case , yes , one red from the dimmer would then be connected with that white at the switch box.
    Is it possible the dimmer is faulty ? -- perhaps --- anything is possible.
    However, one thing that might be the case here. Perhaps the 3 way dimmer switch you are trying to replace has the *common* tied directly to the light. The electronic dimmer has the * dimming * output only on the travellers.
    Verify which 3 way has the constant feed for the *common* --- if it's the other one then try connecting the electronic dimmer at that location to see it it works.
