    Feb 2011
    Default want to run electric from basement to attic
    can anyone tell me what is the propular wiring to run and what fuse to the box
    Default Re: want to run electric from basement to attic
    When you apply for the permit that information will be provided .
    Columbiana, Alabama
    843
    What kind of load do you want to run in the attic?
    If it's just a fan and a few lights 12#-2 romex with a ground should work fine.
    You will need to install a 20A fuse or breaker.
    Maurice Turgeon, thesemiretiredelectrician.com
    wisconsin
    159
    you are going to have to find out your ordinances here. a 12/2 would probably be sufficient, however certin locations require all wiring to be in conduit such as emt, or fmc. you will need to know what is required in your area.
