    Sep 2007
    Default Carpet Pad on Wood Floor
    I just bought a flip house and pulled up the carpet and pad. The floors are still in great shape and have a great shine to them. Unfortunatly bits of the old foam carpet pad are sticking to the floor. I can get down and put some elbow grease into it and rub the gum-like pieces off, but I have two rooms to go and can't feel my fingers anymore. Does anyone have any good ideas other than suck it up and do it.
    1,604
    Default Re: Carpet Pad on Wood Floor
    I would try rubbing the bits of foam with a rag & mineral spirits. The mineral spirits shouldn't affect the floor finish.
    Open a window & be careful with the soaked rags.
    Sep 2007
    I tried that approach and the mineral spirits take some off, but the gooey black spots still remain and need a good hard scrubbing to get off.
    1,604
    How about Goo Gone. Be carefull & check that it doesn't effect the finish. Possibly a white scotch pad to scrub it.
    Don't use Goof Off. It will most likely take off any finish.
