Results 1 to 10 of 17
    Feb 2011
    Default White, Black and Red wire question
    I'm installing a new light fixture in the bathroom of a house we are remodeling. It is a simple white and black wire fixture with the ground wire.
    The previous fixture had been removed before we took over. There are 2 white wires together, 2 black wires together and one red wire all capped off coming from the wall unit.
    One wall switch.
    I tried to wire it up in my typical way: black to black, white to white & not using the red wire at all (have never run into this red wire issue).
    No action. It does not work.
    Any suggestions would be appreciated.
    Thank you.
    Default Re: White, Black and Red wire question
    What colour wires are connected to the wall switch ?
    Feb 2011
    I'm not close by it at the moment, but I believe the lower terminal has a red wire, the top has a black.
    Quote Originally Posted by Robert in Santa Fe View Post
    One wall switch.
    Thank you.
    There needs to be a constant electrical feed somewhere --- either this feed comes into the j-box for the light or it comes from the switch box to the light j-box.
    Wherever this constant feed is will be routed to the switch then from the switch to the light fixture j-box.
    If you connected the new fixture black conductor to the j-box black pairs ( both wires ) and the fixure white conductor to the white pairs ( both wires ) then the light should come one and stay on constantly --- if current is being supplied on one cable pair ( black and white conductors ) at the j-box.
    You said nothing happened -- either the circuit is not energized or the black conductors are not the constant feed.
    If the red conductor is the constant feed then the wiring is a bit strange based on the information provided so far.
    You need to find out where the constant feed is located and which colour conductor. Also verify what colour conductors and how many are located in the switch box. Also are there more than one light or a fan or a receptacle part of the same circuit ?
    Post back and we can walk you through this easily enough.
    Feb 2011
    Thank you for this quick response. It all makes perfect sense to me now (mostly, that is). I'll be heading over to that house in the next hour or so and will further check this out based on your advice. If I can't make sense at that point, I'll be back in touch.
    Thank you! Bob in Santa Fe.
    No problem --- let us know how you make out.
