    Default 3/4" hole in cast iron tub
    I have a 3/4" rusted hole in the tub next to the overflow valve. Should I repair the hole w/ Bondo (body filler used on cars) or replace the tub? I need a quick answer!
    Jan 2009
    Needham, MA
    559
    Default Re: 3/4" hole in cast iron tub
    if a cast iron tub has got to the point where it's formed a 3/4" hole in it, i would definitely replace the tub. all i see is more problems down the road if you try to repair it.
    8,065
    Replacement is definitely the way to go.
