    Feb 2009
    Default recirulating pump?
    I seem to remember on of the TOH episodes where there was a long didtance from the hot water heater and the shower. I have the same problem. I also seem to rember that there was a pump that recirculated the water somehow and the net result was hot water sooner at the end. I don't think is was any sort of electric or otherwise water heater. Can somebody help me out please?
    6,016
    Default Re: recirulating pump?
    Here's a demand type http://www.chilipepperapp.com/Default.htm
    Jan 2009
    iowa
    11
    you could also install a recirc line , this would run from the draining valve at the bottom of water heater to the closest point of your hot water line running to your shower ,this enables a constant flow of hot water
