Thread: 220 Line
    Feb 2009
    12
    Default 220 Line
    Is it legal to connect 2-250/20A outlets to a single double breaker? There would never be a time when both outlets are used simultaneously. The outlets are spaced 2 ft. apart and I've run out of breaker panel room. Thanks
    Feb 2009
    693
    Default Re: 220 Line
    Sure.............
    5,789
    At this point there is no limit on the number of outlets you can install on a line in the U.S.
    Shamokin, Pa.
    645
    Quote Originally Posted by penguin View Post
    I agree with the other posters.
    Top notch advice presented.
    Just wondering aloud, what will the outlets be used for?
    Feb 2009
    12
    To just wondering aloud; 220 outlets will be used for woodworking machinery.
    1,577
    As a rule of thumb (and I'm sure there are exceptions), any appliance that is cord-and-plug connected and not permanently attached to the building is considered portable and therefore doesn't need a dedicated circuit; any appliance that is hard-wired requires a dedicated circuit.
    One exception that I can think of is hard-wired electric baseboard or wall heaters -- it's fairly common to install multiple units on a single circuit, totaling up to 80% of the ampacity of the circuit.
