Thread: Wiring question
    Feb 2011
    Default Wiring question
    Please help!
    I was replacing the fixture and found the following:
    Inside the ceiling box there is one black wire and three (?) white wires connected together with one white wire coming out of this connection (4 tails are connected together - 3 in and 1 out).
    Before removal there was the 70s shop light fixture (fluorecent) holding 4 40W long tubes.
    Any ideas if I can use a regular incandecent fixture for replacement?
    Additional info - the wall switch looks kinda fancy (especially for the 70s), and may be wired for a dimmer (?). Cannot check with prior owners - it was an estate sale...
    Thanks!
    Jan 2011
    Columbiana, Alabama
    843
    Default Re: Wiring question
    The wiring does seem a bit odd but if the old fluorescent light worked so should an incandescent. What colors did they land on the switch?
    Maurice Turgeon
