    Sep 2009
    Default Low shower pressure in second bathroom
    I have low water pressure in my neighborhood and in my second bathroom.
    Can a new shower head increase the water flow in the shower? If so, what is the best shower head, or would a home pressure booster help?
    Thank you
    Jan 2011
    Default Re: Low shower pressure in second bathroom
    Thanks for the info.
    Feb 2011
    USA
    If your shower pressure is slow then you firstly check your pressure. I think in your shower has some fault. You can contact the plumber because recently i have also suffer this problem in mine bathroom tap but i have contact directly to the plumber...
    Feb 2011
    7
    We had this problem as well. We had old galvanized piping running to the main bathroom. The addition to our house was done in copper. The water pressure in the main bath was extremely low and getting some brown water. While the low flow shower head at least allowed us to get wet we were forced to to re-plumb. I would try the low flow to see if it can get you buy until you can save up to replace it if you have galvanized piping.
    Feb 2011
    USA
    If shower pressure if lower to your second bathroom then what you can do is that you try to give direct supply of water to that shower.
