Results 1 to 7 of 7
    Feb 2011
    Indiana
    Default Pipes Banging - Washer
    A couple of years ago we purchased a new side load washing machine. During the wash cycle the pipes bang. I'd like to know, are we getting air in the line or is it the pipes are loose and ones banging against the other? Since I tend to think the pipes are loose I'd like to verify my position before I go in and tear the drywall down to gain access to these pipes. We have no problem anywhere with air in the lines but here. Help!
    Jan 2009
    Needham, MA
    559
    Default Re: Pipes Banging - Washer
    all you have to do is to install an "air eliminator valve" or "air relief valve" at the point where you connect the washing machine hoses to the water supply. problem solved.
    South*East
    1,257
    Quote Originally Posted by MLBSF View Post
    I gave the same reply 12 hrs. ago with a link to a site showing them. For some reason I got a message that a monitor had to approve it before posting . Whats with that?
    John
    Feb 2011
    Indiana
    Thank you for the response. This crossed my mind at one point & I recall asking someone about this opportunity, but sounds like I was not asking the right people. John I have no idea why the link didn't go through, perhaps you can give me the site and I'll google it. Again thank you both.
    Jan 2009
    Needham, MA
    559
    john,
    that's never happened to me before....ask the moderator
    Dec 2009
    40
    you should still strap your pipes if they are loose.
    Feb 2011
    Indiana
    I purchased the air relief valve as suggested, both hot and cold. Problem fixed. Thank you.
