    Jan 2011
    rochester new york
    Default non yellowing protection
    i would like some suggestions for non-yellowing, clear protection over newly stained doors, trim work and molding. Applied stain is oil based.
    Sep 2008
    Fargo, ND
    144
    Default Re: non yellowing protection
    Hi JDR!
    Since your stain is Oil, Oil topcoatS are best. HOWEVER...Oil-based finishes, like Polyurethanes, are amber to start with. You "can" use a clear Water-based Poly on top, but the Oil stain must be COMPLETELY dried through....usually about a week.
    You'll tend to get more grain-swelling when using water-based finishes, and you have to apply more coats than oil-based poly's.
    Sikkens has some good water-base poly's, as does Zar. FPE on the high-end of things, has some awesome finishes in Oil.
    Faron
