    Feb 2011
    Question Soldering Copper
    A dumb question, but I need to make sure I can do this before I cut the pipe. Is it o.k. to solder flexible copper tubing to rigid copper tubing?
    South*East
    1,227
    Default Re: Soldering Copper
    When you say flexible copper are you referring to soft copper? If so then yes you can. Soft copper comes in coils.
    john
    2,969
    Or are you talking about the flex lines used to attach a hot water tank? They can be soldered, but normally aren't because it makes removal a PITA.
