    Jan 2011
    Unhappy leaking bath drain
    Hi, I am new to the forum nice to meet all, my problem is a bath sink drain that has a pin hole in it and it is in the wall, is there a produce I can put in the drain and stop the leak. I do not want to cut out the sheetrock if I don't have to. Thanks
    South*East
    1,227
    Default Re: leaking bath drain
    Cut the drywall and replace the section of pipe. There is no easy way. My guess is it's DWV copper and it's not just the pinhole that you may be able to see that is bad.
    John
