    Jan 2011
    Default T-11 Siding and Decking
    I have a home with T-11 Siding...this is like a plywood with 1 inch groves in like panelling.
    The deck board but up to this siding, and I have found out that it has rotted out, and I will have to replace the siding that come in 4X8 sheets..but after I get that done, how do I keep this from happening again? what happens is the dirt and stuff get in the groves and then sit there and rot the wood...it was painted and such and the deck is pressure treated...
    Thoughts...thanks...
    nova scotia, canada
    1,522
    Default Re: T-11 Siding and Decking
    proper flashing of the deck ledger and making sure there is a air space between the siding and the deckign are mandatory so that no water that sits on the deck is absorbed up into the siding
    Oct 2009
    KS
    19
    I agree flashing will make all the difference. I have the same siding and problem and when the idiot built my deck 2 years ago, he didn't put any flashing down. Now I'm going to have to retrofit some flashing when I re-side the house in the next year or so.
