Thread: Help with drain
    Default Help with drain
    I have an "Old House." It has the black pipe for drains. The newer sink that was put in before me is pvc through the p trap down about two feet. Where the two join i get leaks from time to time. Help me fix this
    Default Re: Help with drain
    Quote Originally Posted by can't get right View Post
    You need to clarify what you mean regarding *black* pipe.
    Is it ABS or cast iron?
    What kind of joint connection is in place?
    Cast iron I'm pretty sure. it has a female pvc coupling that goes over the cast male but isn't getting the job done.
