Thread: leaky flu stack
    Default leaky flu stack
    I have an abandoned furnance flue stack that leaks. I have converted to a high efficiency furnance and electric water heater so the old gas flu stack is unused and capped off. I am getting water dripping out that I assume is condensation now that there is no draft to move the moisture out. It is over a finished suspended ceiling so I would like to stop the leak. Any ideas?
    Sep 2009
    florida
    598
    Default Re: leaky flu stack
    Dont assume anything..........You need to investigate the problem to see where the water/moisture's coming from.
    Gizmo
    Hidden Content
    Hidden Content
