Results 1 to 7 of 7
    Feb 2009
    Norman, OK
    Default when water comes out tub spout it also leaks out shower head
    We just replace all the water supply lines in our house with pex and we have all new fixtures. In our bathtub we have a new KOHLER® Fairfax® Rite-Temp® shower valve, shower head and spout. When I turn on the water it comes out the spout like it is suppose to. When the water pressure is increased it starts to come out of the shower head as well. This problem occurs with the spout and shower head on or with just the pipe stubs only. All the parts are new. I flushed the system out before installing fixtures. Could the issue be my water pressure is to strong, If so how do I reduce it?
    Thanks,
    J.D.
    South*East
    1,242
    Default Re: when water comes out tub spout it also leaks out shower head
    Most tub and shower valves will tell you NOT to use PEX between the faucet and spout. What happens is the ID of PEX is smaller then copper causing some water to backup to the shower head when turning on the spout with full volume. The other cause could be is that you have the faucet upside down.
    John
    Feb 2009
    Norman, OK
    The installation instruction did say whether or not Pex was permissible to use between the valve and the spout or the shower head. The valve is not upside down I am sure of that. I don't believe using the Pex was the issue because they make the diverter with a few different connections. One of which is pex on all four connections. I thank you for your response, but I don't believe that is the issue.
    South*East
    1,242
    I may be wrong but when I look at there valve for PEX I see PEX for the hot and cold only. Not for the spout & shower the have copper or threaded connections.
    John
    http://www.kohlerserviceparts.kohler...abd1697a9f14f0
    NOTICE:
    Use only 1/2pipe (galvanized steel) or 1/2(5/8OD) copper pipe (type
    L or M) between the valve and bath spout. Using other materials may cause
    backpressure and result in water flowing from the showerhead and bath spout at the
    same time.
    The above is from the installation instructions
    South*East
    1,242
    Thanks Canuk I was trying to find that.
    John
    Feb 2009
    Norman, OK
    Thanks guys. Once you explained it a little more it makes complete sense. I guess I am going to have to open up the back of the wall and change out the pipes.
