    Jan 2011
    Default Lally Column questions
    I recently bought a house and at some point 2 of the lally columns were taken out and replaced. the basement is basically unfinished and the other columns were boxed in wood. today i started demoing the basement and when i removed the boxed in columns i noticed they were alot bigger then the 2 that were replaced. is there a specific diameter they should be
    Jan 2009
    Needham, MA
    559
    Default Re: Lally Column questions
    depends on what they're made of and what they're filled with. also depends on what they're supporting
    Sep 2009
    florida
    598
    Most are 3 1/2" if there sitting under Steel/Iron I-Beams. Some are filled with cement some arent .
    I would imagine you will get all kinds of different answers. Construction techniques are different from one state to another.
    Gizmo
    Hidden Content
    Hidden Content
