    Feb 2009
    Default solar tube lights
    solar tube lights were installed on a project. what is the name of the company that makes them?
    6,970
    Default Re: solar tube lights
    Didn't see that episode so I cannot say what brand the show used. There are a number of solar tube companies, I personally like the SolaTubes brand best.
    Feb 2009
    thanks for the tip
    6,970
    I should have also noted that I've installed SolaTubes or had them installed on a number of projects. The fit and finish is top notch and the amount of light you get through them is amazing. There are many different accessories available as well, such as diffusers, lighting, or exhaust fans, depending on the location and needs of the install.
    And no, I have no affiliation with the company, I just really like their products.
