I'm studding out my basement with 2x4's, insulating(bat Insulation) and installing drywall. My question is where should the vapor barrier go? Should I put it on the backside of the 2x4's against the poured concrete basement walls, then insulation between the studs, then drywall or should I put the vapor barrier on the front of the 2x4's between the drywall and the studs with bat insulation? Thank-you for any suggestions you may have.
