    Feb 2009
    Default Ground wire and converting galvanized pipe to pex
    What do I need to do the ground wire that is grounded to the galvanized pipe before I change to pex?
    Feb 2009
    693
    Default Re: Ground wire and converting galvanized pipe to pex
    Remove it.
    Jan 2009
    Needham, MA
    559
    remove it, change to pex. after you're done, attach it to both sides of the water meter, onto metal. clamp it to one side of the water meter, then run a jumper to the other side and clamp it there too.
