    Wisconsin
    Default Textured plaster template
    Hi,
    We are having our brick home insulated from the inside using blown in insulation. The plastered walls are textured and we are looking for a product that can be used for a template to help recreate the "Spanish" plaster over the plugged holes in the walls.
    The idea is to "stamp" the texture back into the fresh patch.
    Appreciate any tips/hints,
    Thanks!
    1925 Dutch Colonial,
    Aug 2009
    Ladson,SC
    192
    Default Re: Textured plaster template
    To make the stamp you can use this product Casting Craft Liquid Latex Rubber Manufactured by Environmental Technology Inc.
    email:mail@eti-usa.com
    This is a brush on rubber and can be brushed on to most any thickness must be applied in many thin coats works very well.
    Your problem is going to be matching the sounding area.There is no SQ/IN ON THE WALL SURFACE THAT IS THE SAME.
    In order to match the area you will need to make the mould before the hole is made to blow the insulation in, this will have to be done for each hole that is cut and each piece will have to be numbered.
    A good artisan can do it with leafing tools.
