    Feb 2009
    Question removing spray paint from dry-wall
    **** spray-paint on white, dry-wall, walls. Is there a way to remove the **** paint? If so, how?
    1,131
    Default Re: removing spray paint from dry-wall
    Not likely. Even if the **** spray paint is lacquer based....lacquer thinner would almost certainly eat the underlying white paint...whether oil-based or latex.
    I think you're stuck repainting more white over the ****.
    San Diego, CA
    367
    I'd use something like Kilz to cover it. It's a good primer. Really thick and should cover it in one coat.
    Good Luck.
    Feb 2009
    have you tried dry brushing the dust off the surface as it does tend to spread when wetted with a damp cloth
    Steve, http://www.fatbuddhastore.com
