Thread: vanity lights
    Default vanity lights
    We removed the old vanity lights & the walls are just plaster
    what shall we apply on walls to attach the new lights?
    8,002
    Default Re: vanity lights
    Depends on the fixture, some require a box to attach to, some attach to the wall. For plaster, predrill a hole and use a hollow wall anchor, there are many types to choose from.
    Columbiana, Alabama
    843
    If the replacement vanity light weighs less than 6 lbs. you use what is called an "old work" round box.
    Leave about a foot of wire hanging out of the wall in the new sheetrock, cut a round hole where you want the light, insert the box, tighten three screws in the box and mount the light!
    thesemi-retiredelectrician.com
