Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Concrete steps
  1. #11
    6,940
    Default Re: Concrete steps
    Quote Originally Posted by victorian View Post
    I was thinking maybe some pvc pipe and a car jack might do it. Someone told me I could actually move my 8x8 shed myself that way.
    And you think it's going to just jump up on those pipes all by themselves? BTW, pvc won't work, the steps will just crush it, use steel pipe if you're going to try it.
    If you can move the steps with a pry bar, then you'll be able to move them with rollers, otherwise you're going to need a bit more grunt, say from a tractor or a truck.
  2. #12
    27
    That's where the car tire jack comes in. Lift one end, slide in a pipe, lift the other end, slide in a pipe, and then a couple in between.
  3. #13
    Feb 2011
    11
    Its best solution in this regard
    concrete is ever lasting thing at all
  4. #14
    Feb 2011
    10
    I want to put forward my humble advice that here, nothing is as suitable as concrete steps. It not only give looks but also strength and support to whole structure.
