Results 1 to 8 of 8
    Apr 2012
    Default Name of a Special Tool
    Hi All,
    I've seen the tool I'm looking for on one of those home shows, probably "This Old House" or one of the others.
    Let's say you have some stonework and want to make a piece of wood to fit the stonework perfectly. There's a tool to do that but I don't know what it's called. It's made from several metal plates and when you push it against the stonework (or any other uneven surface), the plates take the shape of the uneven surface. Then you can use a pencil to trace the shape on your piece of wood so you will have a perfect fit. I know you can use a compass but this tool I'm trying to find would work better.
    Anyone know what I'm talking about? If so, what's it called?
    Thanks,
    mountaindave
    7,972
    Default Re: Name of a Special Tool
    That is called a profile gauge.
    3,160
    They are often found in the tile section of the big box stores. Mine is blue. I've seen red ones and some are metal.
    Apr 2012
    Called a contour gauge
    Harbor freight shows one under "specialty measuring tools" for $4.99
    Sep 2009
    florida
    598
    Quote Originally Posted by DIMAR888 View Post
    They have been around for yrs...........
    http://www.amazon.com/s/?ie=UTF8&key...l_2wluxpt2ta_b
    Gizmo
    Hidden Content
    Hidden Content
    Apr 2012
    Thanks! Without a name I couldn't find one.
    2,689
    You couldn't just go and ask for a "thingumajiggy that you push against something else to copy it from"?
    Don't worry, I can't get myself to do anything like that either That's why I hang out here- keeps me from looking like an idiot!
    Jul 2012
    10
