    Question removing knotty pine wainscotting
    I would like to remove the 1949 knotty pine wainscoting in my dining room. Previously I painted over it, but I would really like to remove it as it has this very 3 dimensional look. When I removed the molding/trim it appears the wood was not placed over the drywall, but rather the drywall ended and the wood was partially embedded into to the wall. Is there any hope for this project? My husband doesn't think so.
    8,044
    Default Re: removing knotty pine wainscotting
    Can you post pictures of the wainscoting and drywall, particularly where they meet?
    It is unlikely that there is nothing behind the wainscot, it would be extremely drafty otherwise. Without seeing the issue, it will be hard to say just how much work it will be to remove the wainscot and repair the wall. It's possible that you'd need to strip the wall from floor to ceiling and replace the drywall and everything. You may (probably ) be able to just remove the wainscot and fill in the drywall.
    1,945
    Smile Re: removing knotty pine wainscotting
    Patti,
    First, I am surprised that a 1949 house has drywall in it. I am also surprised that it does not go all the way to the floor. In any event, the studs undoubtedly go continuously from the ceiling to the floor. There must be horizontal wood blocking into which the knotty pine could be nailed. If the pine is pulled off you should see studs at the same level as the back of the drywall. If this is so, you should be able to splice in horizontal sheets of the appropriate thickness drywall. You can then tape and mud to the existing drywall.
    You might have to adjust the door casings and trim to the new slightly lesser wall thickness.
    Homeowners are not born knowing how to do these things. You learn by doing. Go for it! Your husband just wants a justification to avoid the project and watch football!
    Sep 2009
    florida
    598
    Thumbs up Re: removing knotty pine wainscotting
    Patti,
    Well Duh....Why would she want her hubby to miss the best football game ever to be played tomorrow ....This game will be bigger than the Super Bowl........
    Chicago Bears VS Greenbay Packers
    NFC CHAMPIONSHIP GAME
    Sunday 2:00 PM EST
    Go Bears
    Gizmo
    Hidden Content
    Hidden Content
    1,522
    if there wasnt any drywall underneath the panelling theres a high chance the pine would have started to turn black at the edges do to any draft blowing through. and yes to posting a pic its the only way of having a better idea of whats going on
    as for chicago, puh, GO PACKERS!!!! a super bowl with chicago would be un-bear-able
    8,044
    There's only two football games that I watch ... The bud bowl and the lingerie bowl ...
