Thread: closet flange
    Feb 2009
    Question closet flange
    The drain pipe for the toilet in my basement was set at a slight angle so the closet flange is somewhat tilted. Is this a problem? or will the wax ring take care of any differences from front to back?
    Feb 2009
    17
    Default Re: closet flange
    depends on how tilted it is. if it's slight you should be ok with an oversized wax ring. just watch when you mount the toilet that it sits flush with the floor and doesn't rock. you may need toilet shims if that's the case.
