    Feb 2009
    Default finding matching bathroom floor tile
    Several bathroom floor tiles are deteriorating and should be replaced. The problem is finding matching tiles. Green tiles in the attached photos are 2 3/16" X 2 3/16". White tiles are 3/4" X 3/4". A few years ago we saw this pattern in a carpet and tile store. However, this pattern is no longer in stock.
ID:	2169   Click image for larger version.
    Default Re: finding matching bathroom floor tile
    I do not know what part of the country you are in. but some vendors will do custom color matching. In Northern CA. Heath Ceramics, and Fireclay will do custom colors. There is a Vendor in Portland OR, that will do custom color jobs, but I do not recall the name
    Dec 2008
    11
    Another solution may be to "steal" some tile from an obscure place if you can gently pry them up. How about under the toilet? If you work toward the back, you may be able to get some. Also, is there a closet that is tiled?
