    Feb 2009
    Default HELP! US WINDOW MANUFACTURERS of DH Wood Windows circa 1970
    I own a 35 yo Ranch with 14 double-hung windows made completely of solid wood either hard pine or spruce wood construction. This type of window construction was ubiquous for years until vinyl came along. They are single pane, multi-lighted windows. They have an aluminum springloaded weatherstrip which guides the sashes. Two of the house windows were damaged and I want to replace them with the same construction as all the others. Is there still a US manufacturer making these windows that date prior to the ubiquous advent of vinyl windows in home construction?
    Jan 2009
    6
    Default Re: HELP! US WINDOW MANUFACTURERS of DH Wood Windows circa 1970
    It will be hard to find non insulated windows, and why would you want to?
    You need new windows anyway, find a good replacement and start doing them
