Results 1 to 10 of 10
    Jan 2011
    Default Water heater drain valve
    Shortly after I bought my five yr. old house, I tried to drain the sediment from my electric water heater. I was unable to open the drain valve by hand so I tried using a pair of water pump pliers. The knob is made of nylon so I didn't want to break it off or strip it so I gave up trying to open it. The valve is located very close to the floor of my garage so that I'm just barely able to screw a water hose onto it. How do I get the drain valve opened without breaking it?
    3,120
    Default Re: Water heater drain valve
    Those valves are notoriously cheap and crappy. They are best replaced by unscrewing the entire valve and installing a new one with a threaded base on the new brass valve.
    If your gas heater sets on the floor of your garage, that is a fire hazard. Most fire codes require the tank to be at least 18" above the garage floor. There are stands made specifically for this purpose. You may do yourself a huge favor by having the water tank lifted from the floor. That would make access to the valve a lot easier too. Check your local building code to be sure of the height requirement.
    If your HWH is electric, be sure to turn off the electric before emptying the water, as you run the risk of burning out the electric heating elements if they are not submerged in water and left on. Flip the breaker to turn off the electric to the heater. Gas heaters can be flushed easily after turning the gas valve off.
    Last edited by HoustonRemodeler; 01-14-2011 at 05:43 PM. Reason: added link, added local code check
    Dec 2009
    40
    why does an electric water heater need to be 18" off the floor? theres no fire hazard from combustibles.
    Midwest
    179
    When I install a water heater I always recommend replacing the cheap plastic valve with a full ported 3/4" ball valve and a short nipple. I also put a 3/4" plug in the valve to prevent accidental floods. Most cheap valves will unscrew, but I always have a broken nipple remover to fall back on, but you will still have a flood until the tank drains. You can take a hacksaw blade and wrap it with a bunch of duct tape to make a handle and then stick it inside the broken plastic pipe piece, to saw through in two places about 1/4" apart near the bottom of the broken pipe.
    Then grab this piece with a needle nose and pry it out. The other piece will unscrew. Make sure the teeth are pointing towards you when you make the handle, and don't saw into the steel threads on the tank if possible(keep the blade level). Wrap the new nipple with about 4-5 wraps of teflon tape before installing. You will also need a 3/4" pipe to male garden hose brass adapter to use in the outlet of the valve, to hook a garden hose to. The benefit of a full port valve is that you can flush the tank once a year and remove scale. You will not suceed in doing this with a reduced (standard) port valve.
    "Lead by Example"
    South*East
    1,241
    I have never heard of a electric water heater having to be on a stand in the garage. Gas heaters had to be 18" off a garage at one time, but that is no longer necessary since they now have a sealed combustion chamber. The reason for gas heater being installed 18" off the floor was the old heaters had a open combustion chamber that could ignite gasoline fumes in the garage.
    John
    Sep 2009
    florida
    598
    John
    In Florida water heaters have to be off the floor 18" by code. If not they need to have a "Bollard" post in front of it 36" hgt to keep vehicles from hitting the tank.
    Gizmo
    Hidden Content
    Hidden Content
