    Dec 2009
    16
    Default Water Heater Expansion Tank
    How do you size an expansion tank. I will be replacing all piping & gas heater. I see 2 gallons & 5 gallons at the store...
    I will be placing a 40 or 50 gal. gas water heater.
    Thanks
    South*East
    1,250
    Default Re: Water Heater Expansion Tank
    Two gal. is large enough.
    John
    Dec 2008
    Midwest
    174
    Two gallon should be fine. just make sure you pressure the tank to your water pressure. Usually they come precharged at about
    40lbs. If you have a water pressue gauge just set exp tank the same. pretty easy task.
