    Default IS IT SAFE TO REDUCE WIDTH OF load bearing wall?
    Load bearing wall in the downstairs kitchen area; built (not attached to) at the end of a kitchen cabinet; wall size 43" wide by 8' x 3-1/2; nothing but open bedroom floor space above it on the 2nd floor; I want to decrease the width by 6" on both sides (total of 12") so that it is close to the same width as my kitchen counter top/cabinet.
    612
    Default Re: IS IT SAFE TO REDUCE WIDTH OF load bearing wall?
    Is this 43" wide load bearing wall under a beam? I don't understand how a 43" wide wall is load bearing by itself to a room above it. Something must extend on either side of the 43" to match the width of the structure above it for it to be bearing that load.
    2,009
    Only by opening up the wall & looking at it could anybody give an informed opinion.
    3,201
    Ed has a point,
    You have to open the wall and take a look. I highly doubt the entire width of the wall is load bearing, normally loads are set over a few wall studs in one location, and a few inches wide. That space probably contains a few pipes, wires, or ducts which may make this idea a mute point.
    Take a look inside. Post a pic of what you find.
