    Feb 2009
    Question Replace gas insert with pellet stove
    I currently have a gas (propane)insert fireplace. I want to know if it is possible to replace the insert with a pellet stove or pellet insert?
    Thanks
    612
    Default Re: Replace gas insert with pellet stove
    Depends on the construction materials of the current surround, flue pipe, chase, roof or wall penetrations and clearance measurements of the existing lp fireplace vs. what the model pellet stove/insert requires.
    See what the requirements are for a couple possible models of pellet stoves and compare to what you have to see what amount of modifications ($$) are necessary for your existing set up.
