    Feb 2009
    Default Prehung interior doors - right or left
    How do you know what to buy for prehung interior doors. I have several doors that open in to the room and several doors that open the other way. If the door opens in to the room, is it a right knobed door? if the door opens into the hall way, is it a left knobbed door??
    7,597
    Default Re: Prehung interior doors - right or left
    Without more specific location information, the rule of thumb is that a door should open against the wall, meaning the least obtrusive "open" position. As an example, an entry closet that is behind the front door would open against the front door. One would assume that guests would enter, the front door closes, then coats are hung. If a door is in the "middle" of a wall, then it will swing to the nearest side wall, again assuming the least obtrusive "open" position.
    5,942
    As you stand on the outside facing the exterior side of the door left handed has the hinge on the left and right handed has the hinge on the right , Standard doors open in or toward the interior, reverse doors open out or towrds the exterior.
    Eden, NC
    285
    Wink Re: Prehung interior doors - right or left
    I agree with Jack, the only thing I would add is for you to draw a picture the way Jack did showing what you want. Because you now know the correct explanation and what "swing" to call it doesn't mean the sales person your explaining it to does!
    Calcats
