    Oct 2010
    17
    Default Laundry Room Plumbing. Air admittance valve.
    I'm going to be installing new plumbing in my basement for the Laundry setup (moving it)
    Can you use an Air Admittance valve in place of a vent for the plumbing (they are permitted by code in my boro)? How do you size them for a 2" drain pipe?
    This will be plumbed into a 4" secondary stack that is roof vented (and ties into the main drain under the floor) but as I understand it I should still vent this.
    Roof venting is not really an option for this drain.
    South*East
    1,208
    Default Re: Laundry Room Plumbing. Air admittance valve.
    If it's just for a clothes washer the drain should be 2" and the vent 1-1/2".
    John
    Oct 2010
    17
    thanks. are the Air Admittance valves based on vent pipe size?
    Is there a benefit to sizing the vent to 2"
    South*East
    1,208
    If the vent is 1-1/2" there is no benefit to use one larger then the vent size. Many of these valves can be used on 1-1/2 or 2".
    John
