    Jan 2011
    Maryland
    Default Sill plate/rim joist insulation
    I would like to insulate the area on top of the sill plate and against the rim joist in my basement. It will be area in between 16" o.c. ceiling joists and parallel to joists at ends of room. I am thinking rigid foam insulation cut into appropriate sized panels. Should I also use spray foam around edges? Any ideas? Thanks.
    nova scotia, canada
    1,522
    Default Re: Sill plate/rim joist insulation
    you got'r pontica, thats exactly what works best especially the spray foam around the perimeter. if you can swing it get ahold of a real spray foam gun that the can loads into the top, much better control and 100 x less messy. after that first piece of foam goes on and is sealed you can stog some batts of fibreglass in there for added r-value
    Jan 2011
    Default Juice for fasting
    Going to the grocery store while you are on a diet can wind up being an uphill battle as you look at all the junk food and other foods that you no longer eat and wish you could still eat them. As a society we put a strong focus on comfort food and junk: these are some of the biggest reasons we have trouble maintain a healthy weight. The odd part is that while we promote and eat all of these starchy foods with extra refined sugars and fats we also set impossible goals to be like the thin models we see on magazines. This is an unfortunate thing precisely because neither is good for us and probably not attainable for the majority of us!
    Jan 2011
    Maryland
    A bit further planning/investigation, I looked at rigid foam boards at local home center (e.g., Dow TUFF-R) they say that they must be covered with thermal barrier for interior installation. I researched Dow website, alternative product Thermax says no thermal barrier required, but hard to find/expensive. What to do? I am thinking small panels of TUFF-R type between joists with panels of 1/2" gypsum for thermal barrier, all sealed around edges with spray foam. Any comments? Thanx.
