Results 1 to 8 of 8
    Default Sealing a wood garage floor...
    My garage floor is 2x6 wood planks, with a crawl space underneath. I live in a snowy climate and water from a wet or snowy car finds its way through the floor into the crawlspace, creating moisture problems. What would you recommend to either seal or cover the floor to make it waterproof?
    1,522
    Default Re: Sealing a wood garage floor...
    if there is going to be a fair amount of surface water sitting on the floor i would seal it. or your can put down vc tile
    Yes, I for sure need to seal it. Looking for recommendations on what type of material/product to use.
    The floor is just like a deck floor, but with no space between the 2x6s.
    Thanks!
    1,522
    your best bet is to use an exterior grade varathane
    11
    what is the final amount for it
    just a single rate please tell me
    Feb 2011
    9
    A wood garage floor can be good & very smooth for all that purpose.
    But it should be completely stuck on.
    Feb 2011
    5
    When I just go through my emails regularly this problem doesn't happen. When I click 'view all unread msgs' first then click on one of the emails from the list and click delete I get code 4 error. Its annoying and I've looked in my options and there's nothing related to the 'view all unread msgs' option. I DO have my regular options to move to the next email after deleting.
    Feb 2011
    5
    I have a side room in the garage, below ground level that needs to be prepped for a new floor. Whatever methods were used years ago have all failed and the wood floor is totally rotten. Am checking for cracks, holes that would let water in. House is 90 years old so I expect to find lots of problems.
