    Default Bathroom on slab
    Installing a shower ,sink & toilet on a slab...sewer line is 16" above slab.I know I can get a toilet with a pump [that will also handle the sink drain]that I can install in wall.do I have to cut a pump into the floor for the shower or is there another way?
    Midwest
    181
    Default Re: Bathroom on slab
    Put the shower on a platform the same height as the toilet?
    The problem with water is
    it only runs uphill when you don't want it to.
    "Lead by Example"
