    Default Remove black adhesive on Wood Floors
    Our pine wood floors were covered with carpet, under the carpet was a linoleum, under the linoleum was a black, dry, asphalt-looking adhesive. Would you have any suggestions on what this is and how to remove it? See picture. (along the bottom of the photo is the black underlay for a carpet - disregard. The top/left mottled looking black is the adhesive I'm refering to above)
    Thanks a million,
    KCM
Name:	Bedroom floor.jpg
    2,917
    Default Re: Remove black adhesive on Wood Floors
    Before you go too far trying to remove it, find out if it contains asbestos. Grinding or sanding would not be advisable in that case. Do you you have local asbestos testing agencies in your fair city? There are testing labs where you can mail a samples to.
    Aug 2009
    Ladson,SC
    192
    Also you should have it checked for lead if sanding is in mind.
    May 2009
    Elyria, Oh.
    245
    You can not sand it off. It will clog the sandpaper immediately. A heat gun and sc****r or paint remover is the only thing that will take it off.
    143
    I agree I think you should have the adhesive tested too otherwise your health could be in jeopardy. While not strictly really for removing adhesive you could possibly use paint stripper to help soften the adhesive. If it contains lead or asbestos though leave it to the professionals. Good luck to you!
