    Default How do you get the plastic/resin showers or tubs clean?
    the tubs/showers with plastic surrounds
    1,870
    Default Re: How do you get the plastic/resin showers or tubs clean?
    Look for a product called "Bath Brite." There seem to be several manufacturers that make the same thing under the same name. You can probably find it at a local plumbing supply house; I've never seen it at the Big Box stores (but then I haven't looked for it).
    The stuff I have is a pink liquid containing phosphoric acid. Be sure to follow the instructions carefully; apply it a full concentration and let it sit for several minutes without drying out. Then rinse it off.
