Thread: in floor heat
    Default in floor heat
    i have in concrete hot water heat and it is run by a clock timer and i am wondering the most efficent way to run this an hour at a time or 2 hours at a time or 15 minutes?
    1,522
    Default Re: in floor heat
    its best to leave it on at all times other than summer months. keep the heat at a miniumum temperature such as 15 deg celcius so that when you do want more heat your not waiting upwards of an hour for the slab to heat up. its far more efficient this way. simply turning the heat off and on can shorten the life of the boiler
