    Question Outdoor water line to house replace/relocate
    My water line from my well to the house has sprung a leak and been repaired 4 times. The leak keeps occurring in roughly the same place - just further and further up the pipe. The line runs under a asphalt driveway. What can I do to replace this line without having to tear up the asphalt driveway?
    Aug 2009
    Ladson,SC
    192
    Default Re: Outdoor water line to house replace/relocate
    I purchased a tool Called Borzit it is a hand held attachment for a heavy duty drill motor.
    Worked very well only used it twice.Cost was around $ 300.00
    Dec 2008
    Midwest
    174
    dig up on each side of drive way. I would use copper to replace. Tie onto existing line with what type of material needs replacing. either hook to excavater or back of truck and pull. It will follow old line out. Used to do this next to meater and close to house for water service replacing and HO didnt want yard interupted.
    1,845
    Another way, if you don't have a lot of rocks in the soil, is to attach a "sweeper" nozzle to the end of a length of pipe, and use water pressure to drill through.
    24
    I am assuming that yout line is probally polyethlene. typically if the pipe leaks once it will continue to in the future. depending on if the line is a straight run, or even a few sweeping turns you may be able to insert the next size smaller line through the existing line. I have done this before, it seems impossible but I have honly had this not work 1 out of probally 40 times. this is the same thing that the gas company typically does to replace faulty ductile iron service lines.
    Sep 2009
    florida
    598
    Im with fencepost, water jet the line in. The first time a friend told me about water jetting I told him he was full of crap. Boy did he teach me a lesson. Since then Ive done it many times over the yrs.
    Gizmo
    Hidden Content
    Hidden Content
