    Dec 2008
    Richmond, VA
    15
    Question Replacing Goodman HK Heat Kit
    I have a Goodman package unit that is, maybe, 20 years old with an HK10 heat kit installed that has burned up and it not working. It happened when the blower went out last year. I'm trying to replace it, but am having a difficult time finding an HK series. Supply houses seem to only sell the HKR series. In fact, I purchased the HKR10 by mistake.
    Looking at the HKR, it seems much "beefer" the the HK that is there now.. wires are bigger, disconnect is larger (still 60 amp), etc.
    I'm pondering installing it anyways by doing some small fab work on the HK's box. (The HK is a distinctive box that encloses the disconnect. I'd have to essentially cut out the old components and mount the new ones and use the old wire harness).
    What are you'll thoughts? Good idea, bad idea? Anybody done this before?
    Thanks,
    Jul 2009
    Northeast
    661
    Default Re: Replacing Goodman HK Heat Kit
    IMHO any time you alter or change anything electrical without the Manufacturer saying it will be OK your asking for trouble. Call Goodmans Support Team and ask them, I doubt that they would go along with it.
    Dec 2008
    Richmond, VA
    15
    On closer inspection it is clear that the electronics are completely incompatible.
    1,387
    Howdy i have reviewed this web page but have not purchased from them. You might want to inquired there for fixes.
    http://www.alpinehomeair.com/
