Results 1 to 10 of 12
    6,053
    Default Hiding HDTV cables
    Just for your information I ran across this today
    Erroneous link deleted see below.
    6,053
    Default Re: Hiding HDTV cables
    Oops, sorry about that click on wrong address window.
    Eliminate messy wires. Conceal cable boxes, DVD players, or any HDTV device with the Acoustic Research HDP100 HD Powerlink SystemThe HD Powerlink System transmits digital high definition signal to your TV via existing home power lines. It transmits the highest quality HD signal available up to 1080p. A lower cost alternative to professional installation that removes the clutter of wires and the expense of wall reconstruction!
    http://www.solidsignal.com/prod_disp...OD=HDP100#MORE
    This is not an indorsemnet just passing along some Info I received today.
    6,053
    Yes, but you can hide an outlet behind the screen. And yes you do need power for it to work but the interconnect cables are gone.
    6,053
    And you get to buy some more electronic thingies.
    Aug 2009
    30
    That's cool. I could have used that myself when I got my new TV and wall mounted it.
    2009 kitchen remodel warrior
    asbolute black granite
    Antique White Hidden Content
    Travertine 18" x 18" floor tiles.
    It looks Great!!
    Oct 2009
    Rockford, IL
    7
    These band-aids are usually only compatible with the lowest common denominator of connectivity options, and certainly cannot be counted on for compatibility with future connectivity.
    To leave yourself plenty of options, fish in a run of conduit or corrugated raceway (ie: "smurf" tube or Carlon orange raceway).
    If you can pull wire to install an AC receptacle, you should be able to do this as well.
    FWIW,
    Today's flat panel pre-wire would consist of a high quality HDMI cable, component video cable (for redundancy/backup if the HDMI fails), Cat5E/6 for network, and the aforementioned raceway stub.
    If you are going to have an LCR soundbar type speaker installed on the panel and connected to a home theater, pull three pairs of 16 or 14 awg in-wall rated speaker wire as well.
    I wish the GCs I worked with were as quality-minded as Tom Silva and Mike Holmes.
    Apr 2012
    216
    Smile Re: Hiding HDTV cables
    I'm betting it doesn't meet the newest V1.4 standards. Nice idea but it needs a USB upgrade port or it will be old news in 6 months....
    Oct 2014
    Upstate NY
    20
    interesting
    Tennessee
    2,024
    Power cables don't have the needed frequency response. The product was discontinued, I suspect for good reason.
    Nov 2014
    11
    for me hiding cables doesn't matter for me
