Results 1 to 7 of 7
    Iowa
    20
    Default cold air coming in
    I recently in June had my house sided and new isulation, but cold air is coming in thru the electric outlets . why is this ? What can I do ? THANKS Roz
    Midwest
    179
    Default Re: cold air coming in
    You may have an older home with no top plates on the walls. This allows cold air in the attic to settle down through the stud cavities to the receptacle boxes. Are your walls insulated?
    There are several kits to put a gasket under the receptacle plates to reduce this infiltration. At most hardware stores and on the web.
    "Lead by Example"
    Iowa
    20
    yes well insulated . House built in the 50,s . thanks for your help . Roz
    Iowa
    20
    what are the name of the kits ?
    Midwest
    179
    http://www.goodcommonsense.net/ouairse.html
    Here are gaskets as well as plates with caps for the recept. openings.
    "Lead by Example"
    Iowa
    20
    Midwest
    179
    Sorry for the delay.
    These
    http://www.goodcommonsense.net/oulise.html
    "Lead by Example"
