    Jan 2009
    Default Smelly hot water
    3 months ago I put in a new electric hot water heater. Changed over from an old oil boiler. After about 2 months I started to get that rotten egg smell and discolored hot water. The cold water is fine. I have a well and there is no sulpher smell or taste in the cold water. I changed the anode rod from the factory magnesium to an aluminum rod. That did not work. I have flushed the tank 3 times now with bleach. Letting the bleach sit in the tank for 2 hours then running the bleach thru the pipes for 15 minutes than draining and flushing the tank again. This works for about 2 to 3 weeks than the smell and discolored water is back. Does anybody have an idea or solution to this problem.
    Thanks
    Greg
    565
    Default Re: Smelly hot water
    If you haven't done so already, check out the "Smelly hot water" symptom at the site below.
    click onto "Smelly, stinky rotten-egg hot water" to get to the discussion on this topic.
    Also Google "smelly hot water" and "sulfur odors from hot water", "rotten egg hot water".
    http://www.waterheaterrescue.com
